Is that out ? Or is it in the pipe line?I used mine today im so sorry I want to like it but it ruined the wall and it was only the first coat bring on the 4 foot darby with the Refina plastic
I tried it over 1 bag and its 0 degrees
If I said it was warm what would I do differently? It's standard board I know what a Darby is I don't need too much help on that one ........ Do you think it was because it was cold and the vibration thingymejig or whatever else didn't work or was it because it was early in the morning and the gravitational pull on the moon was at its weakest?
one of my sons use a piece of cavity closer to flatern in his first coat. but he puts his first coat on a lot thicker then we do. so it is every one to their own method. i can not see the reason to rule set, i was always taught to float tight and set tight.It's a Darby I don't know what you're going to try and teach me, I'm happy to listen now if you could give me a few pointers
Hi mate - It doesn't ruin the wall - We have found through customer feedback that any problems in using the Speedskim are due to not following the right procedure.
You just have to flatten in/Speedskim straight away. No waiting for the plaster to pick up. Leaves as flat as pancake....accelerates the general skimming process and yet at the same time the nature of the pvc blade (reduction in surface moisture) buys you time so you are not rushing around.
Less sweat less fatigue.
If you purchased a Speedskim we want you to get the best out of it..
This may be helpful and to others considering purchasing :RpS_thumbup:
Get the best results:
Speedskim/Skim coat 'how to'
- Apply Multi-Finish or Board Finish with trowel as you would normally.
- Immediately after plaster application apply your Speedskim® and flatten back.
- As Speedskim® doesn’t bring any moisture to the surface this now allows immediate application of the second coat.
- Repeat - Immediately after plaster application apply your Speedskim® and flatten back.
- Now wait for Multi-Finish or Board Finish to pick up as you would normally.
- Trowel up or Sponge/Trowel - whichever is your preferred method.
Speedskim Introduction & User Guide link (please note blades are readily available on our website and Speedskim/ebay)
https://www.speedskim.co.uk/downloads/SPEEDSKIM-INTRODUCTION-USERGUIDE.pdf
I don't know you could ask me bod gibbo nick and beddy the same question there's a couple of years experience amongst that lot everyone's said the same it tears it
im terribly sorry but from my experience there more of a hindrance, keep the price the same and change the blade
That's not the feedback from customers who have purchased from us. Interesting list.
There have been one or two paying customers who have needed technical help but after explaining the process and best practice they are very happy with the results. In fact more than happy and wouldn't be without the product
Having said that if you cant get on with Speedskim we have said several times that its down to personal routines and preference. If you dont wish to apply the science and have an easier day we accept your view
What happens then if your on your own doing a 30/40 m2 ceiling by the time you go back to the beginning it would have picked up defeating the object of the speedskim, not having a pop at you cos I bought one a couple of months ago.
It's from people I personally know that are very good plasterers good luck who knows I might get on with it one day but at the mo I think there a ******* useless sales gimmick
Ok once again for the hard of hearing :RpS_laugh:
Lay a bag on flatten it off, then another flatten off. Repeat this until the area is fully covered.
Then allow to pick up. Whip over it with a speedskim again then trowel/spat till finished.
You can have mine
