Stud wall
S a plastering
Hi all got a job to price and its concrete section building was going to put a metal stud in front of it with insulation slabs in-between studs then foil boards would you this will be OK or think it needs something else thanks
The job to process is a little bit different than the one that you are looking at in the likelihood that you can use steel to stud the boards in place of wooden pieces of timber that can be removed from your wall or two pieces of fabric that can fit into the frame or something like that
Stud insulated@ phenolic /vapour barrier @PB ….
Gypline would be better than a metal stud I’d have thought and more cost effective, insulate, vapour barrier boats and skim
