chowyunfatt
Hi, first time posting
I've just rendered a house, my house actually with OCR, my first time using this as I normally do S&C.
Used Weber rend aid, meshed and textured for key. Then Weber OCR 20mm thick and then scraped flat with I bar, pressed with float to form a flat semi smooth, textured finish ready for primer.
As you can see from the two pictures the finish looks like a good key as some I've seen put the primer on to smooth walls. My question is how easy does the 310 primer scrape off the OCR from the people that have used OCR, the primer and TF finish? The problem I have or think I have is it seams easy to scrape off easily. (Ive included 2 videos of examples)
Looking at the video Ive included the main walls seem like a really good bond, I cant really scratch into it or scrape it off so I think this should be OK and not create any problems down the line, but I think the main problem is the reveals, it scrapes off easy IMO.
I dont want to start top coating the TF if there is a problem with the primer, am I being paranoid or does it look like it comes off easy? Will the weather, conditions and time some how blow or peel the TF off stuck to this primer?
Any help would be very much appreciated.
Finish
https://drive.google.com/file/d/1MjbmmGsRvuUhwYRe28nP8aF5K4GjLvp8nw/view?usp=sharing
Primed
https://drive.google.com/file/d/1JblaCLbk4Ex-JmkxcPVCFLqfaYEqpskHnA/view?usp=sharing
Main wall primed, very hard to scratch into or scrape off
https://drive.google.com/file/d/1AAqxQ0Kx2TabuRBfkFDTdaSenzqaNUaXMQ/view?usp=sharing
https://www.dropbox.com/s/j555xgb296cm56t/VID_20170903_102422195.mp4?dl=0
Reveals, easy to scratch off
https://drive.google.com/file/d/1OP4-itEPSo-ZMKhNdDtPyU9m_rTfx58vNA/view?usp=sharing
https://www.dropbox.com/s/g4lpr87z5ei7qjs/VID_20170903_102507794.mp4?dl=0
Finish
Primed
