Hi all,
Let me know how you would do this. I basically cut two chases, 1 for a spur and one for network/coax/ethernet for tv and then went about swapping the surface mounted double gang for a flush one.... except at there was a problem drilling the brick to mount the back box, the brick moved and a load of plaster cracked/fell off.
..I am thinking, put the flush electric box back in with mortar and make it level with the wall, then fill the hole surrounded the box, fill the chases with easifill), remove rad then skim the wall... not sure how to fill the hole around the box as the bricks are uneven so I can't just trowel bonding onto it.
Cheers
Cheers
