11 inch trowel
S a plastering
Does anyone use this size for skimming ive picked up a bit of golfers elbow was going to try one if it helps ease it a bit also any recommendations ie make thanks
Get yourself one of these. It stops you over twisting you wrist which causes tennis elbow. After a few weeks you should find a massive difference.
@essexandy I think does....
Has to be be easier on the elbows over time...
On board work I lay on with a 16 and then speedskim bla bla bla
Yes I still use 11 or 11 1/2in trowels for everything bar screeding.
I dabbled with bigger trowels many years ago and didn't find them any quicker and that they definitely put more strain on the body.
Over time I had three spreads work for me that were having problems with elbows etc. and, once I'd convinced them to stick with the smaller trowels for a good while, their aches and strains went away.
I've used loads of different makes but now just stick with the Marshalltown Permashape.
It does make a difference, dexterity mainly. I sometimes use an ancient carbon tyzack on rendering and an Ox stainless on skim. It makes it less boring as well.
f**k that big trowel of asap and yes andyg use 11 ins .if you have tennis elbow you need a rest and no more f**k**g big sets( as u were)
i was told as a labourer by time served plasterers that these new marshalltown 14 inch trowels would only hurt your elbows , 11 inch tyzacks ruled the day back then , times change but the pain still stays the same lol .
If you have pain you are putting two much plaster on
