Also adding to that, Plaster that is not mixed well enough will cause the same problems.Plaster is not firerated and I doubt ever will or put on paper like one- too many variables to guarantee any level of fireproofing. As for the op question , it's more a case of can you deal with it or not. The fire ratingwill be your last concern. Remixing plaster at late stage is disastrous and you will end up with ripples , dragging, tigers and anything but good finish. If is at early stage , maybe, but still the risk is there. The plaster sets diferent ,in patches, and there is no way you can have the finish you are after. Have I done it? Oh yes. Have I mastered? Oh yes. Have I pulled my hair after seeing disaster result ? f**k yeah! but avoiding at any cost, especially big areas , is a rule . If you are concern about knocking back plaster , think of sponging. Does exactly the same.
I think your trying to teach your father how to f**k there mateAlso adding to that, Plaster that is not mixed well enough will cause the same problems.
The only jobs that can be done with un smooth plaster is beading or dot & dab.
And that gentlemen is ScienceAdding and using dirty water weakens the mix, this causes rapid absorption of moisture on the surface of the plasterer which in turn causes the plaster ( if it adheres ) to be dryer than it should be which then creates a quicker burn time in the event of fire.
I applaud you...I learnt via 'being on the shovel', it was a plastic bath, a shovel cut down at the end to knock up the hardwall and a stick & podger for the finish...it was f##cking brutal keeping to spreads going. They then started giving me cupboards to do...ahhh, heaven!In fairness to the original question I would say that nearly every spreader has knocked gear back up at some stage in their life. But it really shouldn't be done, tried taking the easy option as an apprentice once and got a wack in the mouth from the Labourer ( no kidding ).
f**k**g beast he was, the days before the whisk. He had a lollipop stick and a welded bike cog for mixing and could easy keep to Spreaders going at full pace. Plastering Labouring is an un-respected job and I would argue there isn't any harder job. A decent Plastering Labourer is a rare breed.
Excellent stuff, same here. I wasn't allowed near a trowel and hawk for a year, my boss was proper old school and always said labouring is an art form, if you don't get your mixing right you should get another trade.I applaud you...I learnt via 'being on the shovel', it was a plastic bath, a shovel cut down at the end to knock up the hardwall and a stick & podger for the finish...it was f##cking brutal keeping to spreads going. They then started giving me cupboards to do...ahhh, heaven!
Just a little tip don't dot and dab with plaster no matter how it's mixedAlso adding to that, Plaster that is not mixed well enough will cause the same problems.
Wow.... I've used bonding all my working life. :-( the things you learn.Just a little tip don't dot and dab with plaster no matter how it's mixed
From tomorrow yes just been mucked about last weekYou busy.?
Came here to learn, a bit to educated for my head but certainly explained cheers.If I might be so bold.
Yes it does.
No it doesn't.
Gypsum plaster (board, skim, backing plasters) calcinate when exposed to high temperatures. The chemically bonded water is purged which forms a layer the thickness of which increases as the temperature and duration increase. It's an accurate enough reaction to be used in fire investigation.
That calcination process will occur faster if there's less chemically bonded moisture, which will neither increase nor decrease the fire resistance. It simply means that the initial calcinated layer (which is what gives gypsum it's fire retardant properties) will form quicker.
Few days off for me also, back Thursday.From tomorrow yes just been mucked about last week
Because I wasn't bothered. Just did the wall and did some plasterboarding and went home the f**k.How come didn't skim ceiling?
Appreciated mate, had a bit of a rough time on here so far. Own fault. I was trying to be funny. (Didn't go down well) .There's always something new to pick up, which one of the (few) good things about the building industry. Anyone open to learning new stuff is always going to do well.![]()
Lol everyone gets a rough time on here mate, it means they like youAppreciated mate, had a bit of a rough time on here so far. Own fault. I was trying to be funny. (Didn't go down well) .
Yeah...your right, just trying to get known I guess. I will hopefully get the hang of it. I've learnt already and even after 22years it's great to get feedback. Nobody knows everything and in any building trade no job is ever the same. CheersYeah mate, I think that's cos ur giving out advice on retempering gear and fire-retardant qualities of gypsum...after asking "do I PVA bonding before I skim"
Half of us r probably on our man period tho lol, poor Kate had to verify her ID before her photos of bad plastering were taken seriously in the other thread
It`s a fun place here tho![]()
Stuff the rest of them, you are sound, only once or maybe twice on thread that anyone has even mentioned the finish,alot of posts have been off spreads who have had many year's plastering and imo one coating or even 2 with same mix is an art that comes with experience (some may say it isn't),besides the ins and outs of weather it is right or wrong imo the op should be encouraged to do 2 coat system of skimming to achieve best finish possible.Appreciated mate, had a bit of a rough time on here so far. Own fault. I was trying to be funny. (Didn't go down well) .
Since I have been on here ( which isn't long ) I have noticed that different people have different working practices. Wether it is right or wrong is down to veiwpoint, but anyone who says they have followed the rules completely in building is either a liar or a f**k**g good blagger.I've second coated with the same mix that I layed on with plenty of times
There's nout wrong with it the trowel time are different that's all.
If am doing 3-4 buckets then a fresh bucket for 2nd coat
And if there's any left I just bang a small ceiling or wall with one coat.
It's each to there own as long as it's left neat and tidy
As I've said beforeSponge Monkeys..? that is f**k**g brilliant.
dont even own a spongeStone the crows , on domestic over skim @Lodan don't for the love of plastering use a sponge and one coat.
Worst case scenario for saving time if it really is a problem, mix fresh laying in gear in bucket used for first coat or do smaller area gauges
