2 coats
Always try and lay down with the same gear i just knock it up slightly wetter, why wait an extra 40 minutes for fresh gear t start going off? Also knocking the gear up makes it go quicker so aslong as your filling your beads and tapes out first and getting your roughing coat spot on its simple :)
Depends if I'm on day work, price, if I supply or if customer supplyed haha.
All honesty ill second with same gear if I can control the set, if not ill second with separate on a larger area
Ye
Met a plasterer that only ever throws both coats on at the same time like out of the same mix anyone else seen this?
Yeh .... The local #Pikeys make a small fortune from the practice .... but they run and hide pretty fast, no hope of any snagging there ;-)
