gooner59
with ewi systems a lot of them stipulate that the cloth mesh is fixed just under the surface of the base coat !! ,is it technically going to make a much difference if it is put -on then rendered over ? as is the case with scrims, if you think about it the holes in the mesh should be the correct size to let the render make good contact with the insulation and bond anyway !!! what do you think guys ??.
if there was a failure can the manufactures use this as a get-out ??.
