Thanks for that. I've absolutely no idea but if you agree with bonding and then skim then I'm happy with that. Which bonding should I buy and in terms of time are the any issues with doing the two layers too quickly or too slowly? Thanks for all your adviceBonding it is then. Even @Andy g couldn't skim that.
But why does he think he can get bonding flatter than s&c?
Hi ,
I'm hoping for a bit of advice. I am in the middle of a renovation and my builder has started to sand/cement the internal party wall. Once this has dried what should be applied next to get the best finish? He mentioned bonding and then skim? Is this correct or is it best to just skim?
Thanks in advance
I meant multi finish to go over the bonding?Skim
No spread should have to bond over a wall he's floated.I meant multi finish to go over the bonding?
Thanks for all your advice gentsI think we all agree it’s not the best job but the only solution is the bonding and skimming
Why add extra processes? The base is sand and cement it should be flat so just skim itHi ,
Thanks in advance
Not sure what makes you think that but I can assure you I have a builder and I am not doing the work myself. He's doing it now whilst I'm at work out of town. ThanksI reckon there’s no builder. The customer has done it himself
BTW - out of town on a business trip, got the secretary with you?
NIf I was you, I would let the builder get on with other stuff, get a proper plasterer in the finish off. Have you had a price on the plastering that has put you off? Don’t risk the builder skimming what he’s already done - I can tell he’s not ever put a straight edge over the render.
N
Thanks. Not a business trip with a secretary.. Just a fixed place of work which happens to be in another town. And no secretary! I saw some of his other work before I contracted him and the finish was decent enough. Obviously I'm no professional so wouldn't see all the flaws.
Thankyou. I'll provide with him with the bonding and multi finish and anything else he asks for and leave him to it.I'd let him worry about it if I were you. End of the day, even if you've been stung, you're not paying til you're happy so you do your work and let him do his.
I wouldn't appreciate what you're doing now.
You just worry about passing it off when he says he's finished and paying the man.
looks good paint itGot back from work late so not able to take any decent pics. I've noticed there are a few cracks and the surface is uneven. Obviously an improvement on the bare brick though!
It'll settle.I personally would tell him to jog on but in more extreme language, that sand and cement is a joke, he hasn’t given it a mechanical key of any form, if that is as pissed as it looks then he will need to scutch that first before floating it out but make sure the sand and cement is stable it looks like it is blowing to me. I think you are going to be in a lot of s**t if you let him carry on
The other wall was pretty much the same. The house has a mix of solid brick, concrete block and stud walls and I think it will make three Job easier if he 'dots and dabs' plasterboard. I want to try and get the best possible finish and feel that with this method the builder might achieve better results. The sand and cement walls are dry to the touch but do they have to be left alone for a longer period? Or is it ok for him to adhere plasterboard to them now? Thanks
Thanks for your replies. The walls will need bonding or plasterboard before skimming so I will have this potential damp problem either way. The sand/cement finish is simply not good enough to skim over. If I'm going to have to go with bonding or plasterboard anyway does it not make sense to allow him to dot and dab as this will give him the best chance of getting a decent finish?
Are you serious you can't use dot and dab or bonding anywhere near damp even if it is rendered batton board and depending on situations thermalite boardsThanks for your replies. The walls will need bonding or plasterboard before skimming so I will have this potential damp problem either way. The sand/cement finish is simply not good enough to skim over. If I'm going to have to go with bonding or plasterboard anyway does it not make sense to allow him to dot and dab as this will give him the best chance of getting a decent finish?
