I'm currently refurbishing a room and in the process adding some internal wall insulation.
The wall has been stripped, electrician has been in and done first fix and my plumber is coming this week to install/reconfigure the pipework for new radiators.
The walls are solid brick and as I am installing insulated plasterboards, we agreed (electrician and plumber) rather than chasing the pipework and cables into the wall, they will run the 15mm pipework and electric cables clipped to the surface of the wall as this will then be hidden by the plasterboards. (I will be insulating with Celotex 52.5mm insulated plasterboards).
However I am now thinking, how exactly will the plasterboards hide the pipework and cables?
- Would I cut into the insulated plasterboard to accommodate the services? I believe this isn't recommended as it could breach the insulation properties of the boards
- My plasterer planned to use dot and dab so would he need to apply additional adhesive to make up the difference?
- Would the plasterboards need to be mechanically fixed to batons instead of dot and dab?
- None of the above and services should have been chased into the wall?
