Ok Guys,
Need some experienced advice before i get the walls messed up. We have a house that has pebble dashing. I'm talking about the slightly larger pebbles ones all over the property. looks ugly. Its also painted and i am not sure if the quality of the pain is good for anything to key onto. I wanted to get it rendered flat. I was thinking of the following:
Option 1: Removed the old painted Render - Best Option, but too time consuming and messy. Also don't want it to crack the newly plastered walls inside.
Options 2: Buy EML sheet. Fix it onto the craggy wall render and then render on top of the sheet.
ADVICE NEEDED: HOW DO YOU FIX THE EML SHEETS. I have read here https://www.plasterersforum.com/threads/e-m-l-fixing.42601/ that we could use mushroom plugs from R&J's but what are they called as i cannot find them. I did not want to drill holes, insert plug, then insert washer and then galvanised screw etc.. and thought he simpler plastic plug with plastic nail may be a quicker option. Any Ideas..?
Thanks.
Thanks.
