Advice
John j
Mono Don
Not damp but any advice on this . It' single skin breeze and really need to get it rendered and painted on side you don' see . Webber on sides ye do. . Just pulling water in round doors. I reckon make that slope to edge then bitchemem (excuse spelling) again to stop reai sitting on that lip. Any other tip, and no should of concretete blocked 1st layer or should of double blocked it ye tight yorkshire t**t posts lol
Mate bell me if you want me to come and have a look.
Single skin brick work, perhaps no dpc? & ground levels also?!
Your f**k*d son knock it down and start again!
It' got doc. It's only shed and only get prob round doors
Pea shingle trench around the outside. Sovereign Rendermix on the inside, rubbed up tight (compacted hard) with good clean rendering sand. Single skin always a problem. Plenty of expanding foam around the frame. A decade of the rosary might help too
The problem is only round the doors . .think it' cause waters sitting on step so gonna put a bit of a slope in front of door and bring rest to edge so it runs of
Where its green algae is telling you that water is sitting there, you need to make sure the water runs off and doesn't sit at the bottom of the frame soaking into the masonry.
That's what i thought . Gonna make a pitch there . f**k knows what I.ll do on double doors at front
