Air problem
Spray
G4 machine !! All set up turn air on at gun and air is coming out but machine won’t start ,! What the problem
Use a different air line that you know is clean and check air tap and air nozzle on gun are clean, just a partial blockage will stop machine air switch.
It maybe due to a restriction in the air flow.
First thing to do to test this is remove all air lines and try this from the front of your machine. If it works, you have a blockage in your airlines
Air line blockage mate , that’s from me only experience I have is use of ritmo m though not sure if yours is the same
Machine runs in Manuel ! but in auto when air on gun is turned on won’t start
Air problem
