The Hobo
steady on cockney ive had one heart attack alreadyLink Removed
Made box to slot in fireplace opening. Dried flowers or something would go in. Used thermal blocks to reduce size of opening then plaster skimmed. There was a small water pool in box from condensation every morning and it was winter. I made small vent in fireplace side wall as hidden and water stopped.Thermal boards ?
Your "exrince expreroindHis off on one again![]()
u pissed or lost your glassesYour "exrince expreroind
What you think if it was thermal boardedMade box to slot in fireplace opening. Dried flowers or something would go in. Used thermal blocks to reduce size of opening then plaster skimmed. There was a small water pool in box from condensation every morning and it was winter. I made small vent in fireplace side wall as hidden and water stopped.
Think damp can come through top if no cowel on pot. Also no damp course under fireplace or air gap like you get with wooden floor so it can be damp. Vent keeps air flowing throughWhat you think if it was thermal boarded
Your nothing but a Cling on ! Your s**t, ! Em done here ! xu pissed or lost your glasses
night palYour nothing but a Cling on ! Your s**t, ! Em done here ! x
l
You need a chimney vented bottom and top. Becouse chimneys get batterd whith rain the moisture that goes in to chimney needs to dry. The idea is to get air circulation going otherwise it going to get trapped in ther. Told you before stick to selling stuffdont put a vent in and see how it goes, if you get a damp breast, vent it, easy as that. thread closed.
tapit tip no.34.
Just read your post on lime render and agreed , think their is a common problem with these posts and replies . many theoretical " bodges " work fine in different areas of the country ( climate ) , not always enough info to form an acceptable approach .You need a chimney vented bottom and top. Becouse chimneys get batterd whith rain the moisture that goes in to chimney needs to dry. The idea is to get air circulation going otherwise it going to get trapped in ther. Told you before stick to selling stuff
Hold on bary John. Your English is to complicated for thick plastrer like me. So in other words your saying thers no need for vents in dryer climateJust read your post on lime render and agreed , think their is a common problem with these posts and replies . many theoretical " bodges " work fine in different areas of the country ( climate ) , not always enough info to form an acceptable approach .
Lol I'm half welsh ( ebbw vale )Hold on bary John. Your English is to complicated for thick plastrer like me. So in other words your saying thers no need for vents in dryer climate
Any good looking ones down southSheep are easier to catch on flat ground lol
what the f,uck you on about?Made box to slot in fireplace opening. Dried flowers or something would go in. Used thermal blocks to reduce size of opening then plaster skimmed. There was a small water pool in box from condensation every morning and it was winter. I made small vent in fireplace side wall as hidden and water stopped.
piss off you welsh t**tYou need a chimney vented bottom and top. Becouse chimneys get batterd whith rain the moisture that goes in to chimney needs to dry. The idea is to get air circulation going otherwise it going to get trapped in ther. Told you before stick to selling stuff
Il have come see you oAny good looking ones down south
If you told that to any other race don't know what would happen. Your lucky I'm easy but some are notpiss off you welsh t**t
i knew you could take a joke no offence intended.Il have come see you o
mnight pal
Shut the f**k up you smooth c**t !His off on one again![]()
Back in ya box ya gobby cnt!m
What box would that be ? Mr SmoothieBack in ya box ya gobby cnt!
One you crawled out of ya pikeyWhat box would that be ? Mr Smoothie![]()
