Hi, I'm internally insulating all my external walls with foam board then drylining with plasterboard and skimming. On my fifth room now.
The window reveals in my house are splayed so the angle between the wall and the reveal is more than 90 degrees. (and the reveals are deep, 40-50cm with the insulation/lining on)
I've been using normal "thin coat angle bead" around the window reveals. But because the angle is wide due to splayed reveal, this bead stands off higher than it should, even if I squash it on and hold with pins while fixing. That makes the plaster too thick both sides of the bead.
I've also tried widening the wings of this bead with pliers, haven't managed to do this without distorting it and messing it up.
Is there a better bead to use and where can I get it? Thanks.
