Many reasons why render would fail. Too strong or weak a mix, rain hitting it, frost or rapid drying. Using too soft a sand is common. putting render up to or onto something that is expandable when the render is not. Out of date products, cheap mesh or plastic beads. Building movement. To many additives or the lack off. Mixing additives that are not compatible. Wrong preparation is common in failures. Not allowing drying/curing times in between coats
Cracks is as we know common and in new render it is not acceptable although a lot of the time it is down to building movement but proving it is difficult so we are guilty until proved innocent. I have a very good book on building cracks and it could get me out of trouble should I get stress cracks. Some cracks are down to the renderer but he may not have known he has done wrong until it is too late.
As for a book on failures? Never heard of one but there are advise sheets on how to do it right so doing the opposite would give you a failure.
