Stevieo
Royal Spin Doctor
boiled egg.Skim bonding same day multi or board
It just a f**k up s**t gearSeen. I hadn't blown the photo up...just thought it was a lumpy wall.
f**k's sake, no wonder he's depressed if he's been doing it forty year and still at that. @Andy g weren't you asking about bonding last week?
Say whatboiled egg.
never seen the stuff in Scotland but seems the same as casting plaster 80 bags or nowt ARSOLESWhy is Pure so expensive compared to other products, some say it’s better than multi why is this and why can you not just buy a bag at your local store instead having to buy a pallet
c**tBoiled egg.
c**tf**k me!! You put that on?
I thought you were complaining about having to go over it.....
@BritishGypsum
Andy G the most successful time to skim bonding is just as it's on the turn to set i find, I hope this helps you with your 8 hour panic attack as a plasterer, don't get down about it, get smart.Skim bond same day yes or no
Feeling really down f**k off
Multi or boadAndy G the most successful time to skim bonding is just as it's on the turn to set i find, I hope this helps you with your 8 hour panic attack as a plasterer, don't get down about it, get smart.
I tryAndy G the most successful time to skim bonding is just as it's on the turn to set i find, I hope this helps you with your 8 hour panic attack as a plasterer, don't get down about it, get smart.
Had a pallet of bg boards yesterday that wernt squair ffs, instead of changing the look of your bags,sort the product out.Hi all,
We want you to know that we value our customers and have a dedicated email address so you can alert us of any problems you are experiencing with the product. As Danny has said in this thread, the more information we get, the easier it will be for us to resolve any issues.
If the product is not performing as it should, we genuinely want to find out why and resolve it. Please email us your number, location and, if possible, details of the problem you are experiencing to [email protected] and someone will be in touch. If you prefer, you can also contact us by sending a DM through our company Facebook and Twitter pages.
We value our customers and do want to make your life a bit easier. We look forward to hearing from you.
Many thanks, the BG Team
I hope that's not common as I always use pb for setting everything square ,Had a pallet of bg boards yesterday that wernt squair ffs, instead of changing the look of your bags,sort the product out.
The bags are rubbish as well,even krend bags are more sturdy.
Noticed the dye on bonding bags coming off.Had a pallet of bg boards yesterday that wernt squair ffs, instead of changing the look of your bags,sort the product out.
Sorry mate but I'm afraid that you are mistaken, as we're I. See you and I thought that square meant that the boards would be, well, square. We are both wrong. In fact as long as the measurements from corner to corner diagonally are within 8mm of each other that means that the boards are square. Now you might be thinking that that could still be the case with a parallelogram, which clearly isn't square, but again you'd be wrong because @BritishGypsum have managed to change the laws of mathematics as to what is termed 'square'. That just shows the power of St.Gobain.Had a pallet of bg boards yesterday that wernt squair ffs, instead of changing the look of your bags,sort the product out.
I'm going to 345 my next lot to check , most disturbed
Panic over , I use knauf , someone got me some BG to put a ceiling up , I honestly thought they were damp they were soft and bendy , pink in the middle , refused to use themSorry mate but I'm afraid that you are mistaken, as we're I. See you and I thought that square meant that the boards would be, well, square. We are both wrong. In fact as long as the measurements from corner to corner diagonally are within 8mm of each other that means that the boards are square. Now you might be thinking that that could still be the case with a parallelogram, which clearly isn't square, but again you'd be wrong because @BritishGypsum have managed to change the laws of mathematics as to what is termed 'square'. That just shows the power of St.Gobain.
Hi @djfleming22, we recognise that buying by the pallet is difficult and so we are working on getting more stockist locations around the country. If you want to buy PureFinish, please let us know your location (by responding to this thread, or emailing us on [email protected]) and we will let you know local stockists.Why is Pure so expensive compared to other products, some say it’s better than multi why is this and why can you not just buy a bag at your local store instead having to buy a pallet
Hi @essexandy, we are sorry that you are having problems. All the gypsum that goes into our plaster comes from the same source, meaning the gypsum used is all of the same quality. If you want to discuss any issues about plaster please send your contact details to [email protected] and someone will be in touch.So can you tell us why Pure Finish is so much better to use than Multi or Board Finish? I find it hard to believe that whatever it is that sucks all the nasties out of the air is what makes it nicer to use.
If the problem is that you only have enough high quality gypsum for the more expensive finish plasters then at least be honest enough to say so, not just deny that there are issues. Also if this is the case then you should insist that stockists hold the superior products, even if it were only Jewsons, being as you're part of the same setup.
There I've been nice and polite. No swearing or name calling. All I ask for is some honesty and for you not to treat us as if we know nothing and all issues are down to user error.
Back to you @BritishGypsum
Hi , what's the score on pink , bendy plasterboard and is it possible for boards to not be squareHi @essexandy, we are sorry that you are having problems. All the gypsum that goes into our plaster comes from the same source, meaning the gypsum used is all of the same quality. If you want to discuss any issues about plaster please send your contact details to [email protected] and someone will be in touch.
Hi @BritishGypsum I have gone through the process of contacting you a while back and talking to an employee of yours and got absolutely nowhere. Your people know where I am if they want to talk again, if not I will continue to slate you and your products as and when deserved (all the time).Hi @essexandy, we are sorry that you are having problems. All the gypsum that goes into our plaster comes from the same source, meaning the gypsum used is all of the same quality. If you want to discuss any issues about plaster please send your contact details to [email protected] and someone will be in touch.
They have just by the b*ll***s nothing else to us , asuwereHi @BritishGypsum I have gone through the process of contacting you a while back and talking to an employee of yours and got absolutely nowhere. Your people know where I am if they want to talk again, if not I will continue to slate you and your products as and when deserved (all the time).
I always blame the labourer!Oh I agree with you totally but with the amount of bags that get used every day if 10 people complain it can be like looking for a needle in a haystack... also it is not always the plasters fault....
some "plasterers" blame their tools and materials to justify to themselves..... (not saying anybody here does that though)
Hi @Donzo, Do you still have a bag where the dye is coming off? If so, we'd like to come out to see it. Can you send us your location and phone number via DM or email it to [email protected] and we will arrange?Noticed the dye on bonding bags coming off.
Hi Mike, Thanks for answering some of our questions but I would like to know why Pure is so expensive compared to other finishes and why is it better than multi finishHi @Donzo, Do you still have a bag where the dye is coming off? If so, we'd like to come out to see it. Can you send us your location and phone number via DM or email it to [email protected] and we will arrange?
Don't you think it something to do whith damp weather the moisture level very high this time of year I haven't had much trouble myself I just adapted to time of year best Time to plaster spring and autumn if the weather is in order be. But seasons have changed all over the place. That the trouble whith skim. if it hot it going to set quicker if moisture level high it going to drag common senseIts been sagging and tearing and taking ages to go off, loads on Facebook saying the same.
Hi @djfleming22, Sorry for the delay in getting back to you. PureFinish is made with different ingredients and additives to our other plasters so is different to MultiFinish. Would you like to try it out so you can see it for yourself? We will contact you privately to arrange this.Hi Mike, Thanks for answering some of our questions but I would like to know why Pure is so expensive compared to other finishes and why is it better than multi finish
IN that case I will have a few bags to try plus a beany hat and 2 xl hoodies for constant stressStarts a thread to talk.
Slangs new product.
Stunning
