Bagged material
item1c
> Bulk Products
Dry Silo Mortars
Hydraulic Lime Mortars
Renders
Screeds
Ready Mixed Concrete
RemixBaggedButton
> Bagged Products
• Mortars
• Screed
• Render
• Post Mix
• Concrete
• Cement
• Kiln Dried Sand
item4 item5 item6 item7 item8 item9 item10
t: 01329 231200
"Build on our expertise"
Suppliers of: Dry Silo Mortars • Hydraulic Lime Mortars
• Renders • Screeds • Ready Mixed Concrete
item15
Applications
Remix Internal and External Render is suitable for use as a traditional two part rendering system for internal and external use in moderate exposure conditions.
Quality
The mix is a kiln dried, pre blended, factory produced 1:1:5 to 6 cement lime sand render incorporating a waterproofing agent.
Mixing Instructions
To overcome any potential segregation that has occurred in transit, thoroughly mix the maxi bag contents before use.
The contents of the bag can be mechanically mixed in a free fall mixer for 3-4 minutes or hand mixed by pouring the contents onto a clean, flat surface and slowly adding clean water in increments and mixing continuously until the desired workability is achieved.
For optimum results approximately 2.0 to 2.4 litres of clean water should be used per bag. Render should be used within 60 minutes of water addition.
Refrain from excessive water addition as this will weaken the mix, delay setting times, adversely affect durability and may also result in colour variance.
In the case of render applications to high absorbency masonry units and/or high ambient temperatures, rapid moisture loss should be prevented by pre wetting the masonry or substrate.
There is no need to add further additives or admixtures to the material on site as all required plasticizers/workability aids are already incorporated into the mix.
Coverage
Each maxi bag of Remix Internal and External Render will provide sufficient material to cover approximately 0.8m2 at 16mm depth.
Please contact us or call us on 01329 231200 for more information.
© Copyright Remix Dry Mortar Ltd
Webmaster: angel-fish.co.uk
Products
Please select the required product to view a
full description:
GPMM
General Purpose Masonry Mortar
RTBM
Roof Tile Bedding
Mortar
RemixSCS
Sand Cement Screed
IER
PMC1
Post Mix Concrete
GPC
General Purpose Concrete
Cement
Cement
KDSbags
Kiln Dried Sand
Bagged material
Is wont go through a pump. Got seperated and stuck in the pipe.
Nice gear for hand use
Sure b and q do it.
2 coat gear n all not for one coat rendering. That old wait a week for the scratch to cure always bugs me
Yer its two coat. Nice mix though and worked at not alot differnet to s+c
All batched for you so labs cant get it wrong
