I've got some bags of it in the lock up might give it a whirl in there and see how it sprays
Have tried cows s**t mate, I think that’s the only thing you haven’t put troughSprays no problem.
Your a true visionaryMy ritmo has seen things that's not even for plastering
Well now I know where is Vincey gone, haven’t heard of him for a long time. Buying Ritmo was good business investment, now you are the only owner of the clemoskimMy ritmo has seen things that's not even for plastering
If you ask through the machine- no , I haven’t yet. Pricing one tomorrow and if I get it will try machine applying. Skimming on site at the moment tho. Problem with Bauwer is it can be quite expensive in some cases and customers can’t justify the cost regardless all the benefits. It’s very tricky to rely on it alone.
I made enquires for the shaft it’s like mission impossible to get am gonna ring les again, anyway that aside I have a full house to do exterior with arenino on top is the spec with rinzaffo coat first before the BauwerRight, after so many enquiries for a shaft for the XL , today decided to try the light plaster shaft . I think for me that’s the way forward. Thought as the bag needs almost double the amount of water I have to set it quite high, but ended up @250. For comparison for mono is 200. Not much difference and not what I expected. It does spray and pushes the gear through the hose , but not continuous. If that’s the only problem I am all in. Not ideal but way quicker than bashing it by hand. Might work the same way with the L & M .
No mate, I haven’t yet.I made enquires for the shaft it’s like mission impossible to get am gonna ring les again, anyway that aside I have a full house to do exterior with arenino on top is the spec with rinzaffo coat first before the Bauwer
Have you used the rinzaffo ?
