Bay window advice
Fixalot
We have to dismantle the rendered are between two bay windows (upstairs / downstairs) in a couple of weeks....as the timber structure is rotten due to water ingress.
Once dismantled, the joiner is going to re frame and board the structure, which we were then going to render.
We were going to use EML, and then traditional sand / cement....but a few guys have mentioned using Blue Board and then OCR (One coat render?)
Any advice / feedback guys?
What I don,t like with using panels is that it becomes segmented like a three penny bit!
I use 6mm ply and wrap it around the bay. This gives a nice curve. Breathable felt and expamet in the usual way. Two coat render.
nice job rigsby,
i would put a few wood laths in the upright position then fit the eml so that the eml does not lay flat against the felt.
