beads
S a plastering
what kind do you use for thin coat applications is it just plastic skim beadswhich go on after the base coat or something else cheers
the beads are usually specified and supplied by the system manufacturer but you can get them elsewhere. thin coat beads are plastic with render mesh wings usually around 150mm lap on them you can get stops and corners in this country but for specific detailing you would have to look to germany. the typical corner is a 3707
