vfr12
MOTORC*NT
So if everything is ok there I'll live you with flynny to investigate further.I've pushed a few back (that aren't nailed) and seems dry underneath. cobwebs and some muck - stuff which doesn't look like it's leaking.
Easier to get up there on a dry day with a hoseHere's pic of that - am not sure water is collecting here (and lead is lipped quite well), I don't think it is but will check after rain next.
I think I've diagnosed the problem or told the best lieSo if everything is ok there I'll live you with flynny to investigate further.
Lol I knew looking at first picture boss, I going bed nowGlad you turned up to contribute to solving the problem lol![]()
Cool I'll check that out will make it easier for me to explain stuff to the not so well educated on here...not nameing NNY names MANyou like them? mspaint. I can do portraits too..
Well d*m**o is banned so you may be talking to yourselfLol I knew looking at first picture boss, I going bed now
Cool I'll check that out will make it easier for me to explain stuff to the not so well educated on here...not name nny names man
So obviousThey are tiles![]()
Easier to get up there on a dry day with a hose![]()
BOOM, @flynnyman might be right onto it. Gypsum backing, condensation, never drying. I would follow this advice, just to be sure get the flashing looked at, make sure there's no holes at the the cladding, and await a dry wall. Good luck.We are getting closer to diagnosing itso you patched that bit up with flash band? Yeh that bit I thought was a hole
the problem may be the chimney is not vented because you still have the flue connected to the cowel and you say the flue is no longer used? What you will have is the void around the flue which is not vented and if the flue is metal it will get cold and cause condensation which may be causing the problem. You also have a gypsum based backing plaster that will hold moisture and will never dry out. I would suggest pulling the flue out so the chimney can fully vent and plaster up with sand and cement.
Hahahahaha that would be the simple solution but I we have to diagnose all the other problems aswellI die a job early this year and they had four firms out who all done work and it boiled down to a chimney that wasn't vented. The guy who's house it was gave me ten ways to do it and I told him to leave it to me and he couldn't believe the problem was so simple once I sorted it. Every day I wish I could get on the gravy train but I can't lie
I have thought about getting other people to lie for me but I can't change
The chimney wall backed into his landing wall which was damp he had the chimney on the roof rendered and also all downstairs they had attached Newton membrane which is what he wanted me to do coz it hid the problem. Unblocked the chimney in a bedroom which was full upto three foot with soot and some bricks problem solvedyou get paid £50 to do the job and £500 for knowing which job needs doing.
this job you mention above, what was the effect of the non-vented chimney?
https://www.fixmyroof.co.uk/install-roof-flashings/
From info above you can check all as should be and if handy correct.
May the force be with youso the soakers on my pics are on top of the tiles? this bloke sits them underneath. is there a right way or a wrong way or is it just an option so long as done well. looking at that vid (and the other step one), makes mine look a bit crap, so I think they need sorting.
I'll nip up there maybe tonight or tomorrow and move some tiles to see how far the soakers sit underneath.
I think it might be worth either me spending day replacing or getting someone in to sort. having seen that vid, I reckon I could do a better job than what is currently in place.
the flue is coming out anyway![]()
Not read any of that just seen the pics I think you know
