joemarsh20
Good morning,
I have joined to try get some advice on Lime plastering in the hope of not been sold something I don't want and a job doing incorrectly, so I hope someone can help.
I have an old Victorian terrace and wish to have an internal wall plastered in Lime to match the existing Lime that is already there. There are lots of other reasons for doing this other than aesthetics etc, and we have a slight problem with damp. This has manifested itself on gypsum plaster which has been randomly used to patch up the original Lime plaster.
My concerns are that the few people I have had to quote the job have all told me different things and I would like to clarify a few points if possible on here:
1) What is the mix for "true" Lime Plaster when applied in a thickness from brick to finished surface of 10mm and 20mm, how many coats would be required to achieve both thicknesses?
2) Is the product Tarmac Limelite (and associated base coat and finishing plaster), actually a true Lime Plaster or is it a halfway house type product that wont truly have the properties of the original stuff in my house?
3) One of the walls to be plastered is original Lime Plaster which I have had to remove the bottom 800-1000mm from the floor, can new Lime plaster be applied and "patched" into this line of original plaster?
4) Another wall to be plastered is the same as above but has had a skim of gypsum applied as well as the rest of the room (which is sound), can this be "patched" into as above with new Lime plaster?
5) Are there any other products on the market I should be aware of that people would try to pass off as Lime plaster, that isn't suite correct as the original Lime in my house?
Thank you so much if you can answer any of this for me.
Joe
Joe
