Have a look at the Winget 150ft.
Do you get your wheelbarrows from Toys r Us?Had one 10 years, holds 5 or 6 wheelbarrows of stuff (If same size as mine) likes petrol but is excellent as easy to pull around.
What litre capacity is it? That sounds huge!No.
You can’t actually decipher what size it is off a photo.
When loading it with s&c it will take 80 shovels of sand and 3 bags of cement.
Or using pre bagged gear, k-rend for example, it will take 18 bags.
Is that better??
It has a smaller drum than the Winget 150TFT, and I sure as hell can't get five barrowfulls out of mine.No.
Is that better??
Remember when I first started the big mixers that needed starting up with the big handle spinning round, all the guys found it highly amusing when I couldn’t get it started. Felt like a real man firing up those mixers.
I think what that shows is that Winget are realistic about how much gear you can put in a drum and get a decent mix out quickly.But it hasn’t has it. Not even the same sport
Yours has a mixed batch capacity of 150litres.
This is 280
