Bent trowel
LTJ
Been wearing a 13inch MT in for a while and was using it on OCR which seems to have bent it only slightly the wrong way, should this come out just through trowelling up?
No. Bin it
schmidt i don't trust you GIF by New Girl
It's the only way I've seen, I remember trying this years ago and it actually does work. Us your stainless or carbon steel?
It’s stainless, I’ve just put the trowel edge against a flat surface on both sides and only the tiniest bit of light came through along the length of the shank, once a bit of pressure is applied it disappears, I think it’s from where render has been pushed on mainly through the middle of the trowel, would pressure from skimming get rid of this? It’s not massively bent or warped
I may have a broken in 13" carbon somewhere you'd be welcome to if that helps
