How do you stick your beads on?I’d say beads too but these ones
How do you stick your beads up there?
View attachment 41352Paper-tape, just pre-soak before using.
Definitely not with your sh1t tape I usually use some spit or this grab adhesive it’s decent gear tbfHow do you stick your beads on?
No need to soak drywall tape mate. We use a banjo to apply paper tape.do you soak the whole roll or each individual strip?
I meant when we use paper tape with Multifinish mate.I know mate I don’t soak mine and not had any failures just wondered what he was doing.
I take it you use a powder mix as appears to ready mixed?
Be good if pink worked on wet wallsPink grip, orange brick tape.
I pre-soak individual strips (not rolls);do you soak the whole roll or each individual strip?
Never use paper tape , even though apparentlytly doesn't need per soaking I would soak along the lines that it would open up fibres on surface of paper and get a better bondI pre-soak individual strips (not rolls);
1. Cut to length
2. Dip in bucket of water and straight out
3. Squeeze wet strip between fingers
4. Lay a tight coat of gear on joints
5. Paper tape straight on and feather out excess gear.
Reasons for pre-soaking ;
1. Helps to get the paper on tighter as you can squeezes out more gear from underneath the paper.
2. As the paper absorbs water, it’s not taking it from the gear on the joint.
3. You can slide the paper around if you need to re-adjust position.
However, I don’t pre-soak metal angle tape.
If tape needed soaking there wouldn't be drywall taping machines that hold the whole roll on them.Never use paper tape , even though apparentlytly doesn't need per soaking I would soak along the lines that it would open up fibres on surface of paper and get a better bond
Not looked into it , see a few modern artex tape failures , with taper areas fine as plenty of depth and moisture it's the butt end that is applied thinly that concerns meIf tape needed soaking there wouldn't be drywall taping machines that hold the whole roll on them.
The original brown Artex tape did need soaking but the later white tape didn't and some companies, such as Lafarge said to use their drywall tape dry with their version of Artex.
Just about every tape failure I've seen is due to too much material being squeezed out from behind it during application. This was a particular problem when the old Artex tape was soaked and used when it was too wet. It was supposed to be dunked and left hanging for a while.Not looked into it , see a few modern artex tape failures , with taper areas fine as plenty of depth and moisture it's the butt end that is applied thinly that concerns me
Like all these products , can't help those who just follow same instructions in all variety of circumstances with no experience or common senseJust about every tape failure I've seen is due to too much material being squeezed out from behind it during application. This was a particular problem when the old Artex tape was soaked and used when it was too wet. It was supposed to be dunked and left hanging for a while.
YOU OWN AN IPOD???Kettle then ipod
Yes, you know how up to date I am, one for work and one for homeYOU OWN AN IPOD???
Oh my god I've slipped into an alternative universe.
