Brand new gear, 07/05-2014 date on it. Not from Jewsons either, because we know that stuff is ****.
Well, the first hit I put on this morning still hasn't browned off yet, that's been on for 6 hours now, that's not down to the temperature.
Don't think so. It was an outside tap, but I'll check in the morning. Why, have you found that it makes a difference, not something I'd ever thought of.
you need impurities in the water to set the plaster. a water softener will kill the impurities and alter your setting time.
I've never thought about that Malc.you need impurities in the water to set the plaster. a water softener will kill the impurities and alter your setting time.
Outside taps aren't usually connected after the softener though are they?
You didn't throw any dry-lining adhesive in it did you?
