essexandy
The Lake Governor
Oasis if your the sort of guy that only does private work doing 3 rooms a day probably seems impossible, but working on site is very different, for a start you don't actually put on a whole room at a time, you can put 4 or even 6 walls on at a time but by doing opposites you can mix the size of the walls you are putting on and amount of metres according to how much suction you are working on or how quickly the plaster is picking up. I often end up doing 4 or 5 smaller hits a day when theres lots of suction, at other times I will do just 2 very large hits a day, when there is little suction, the plaster is slow or both, you just need to be flexible in the way you work, be able to read the situation and have the confidence to sometimes put more on than usual.
