D
Deleted member 29624
Guest
Sounds a winner, I might try it for my high suction stuffThis stuff is waterproof mate it's for external work but very fine unlike that blur s**t lol
You won't be disappointed just allow it to dry the day beforeSounds a winner, I might try it for my high suction stuff
Serious question Greg, if you use it on all your stuff are you happy going day before to prep, sounds hard work being at a job all day and going to another to prep, just wondering if you have a system that makes it easyYou won't be disappointed just allow it to dry the day before
I'l PM you as I'd explain better over the phoneSerious question Greg, if you use it on all your stuff are you happy going day before to prep, sounds hard work being at a job all day and going to another to prep, just wondering if you have a system that makes it easy
Trouble with kids today, so lazy, what’s wrong with running your pva roller aroun five or ten times. I despair the youth of todaySounds a winner, I might try it for my high suction stuff
I always got asked this but after a week or so you are ahead of the game as you pretty much don't have to do any prep the morning of the job. So you are aheadSerious question Greg, if you use it on all your stuff are you happy going day before to prep, sounds hard work being at a job all day and going to another to prep, just wondering if you have a system that makes it easy
LolI always prep day before. If domestic.. Plastic on floor, radiator. Windows, doors ect. Masking around ceiling line. Bang on the blue grit and away.. That's half a days.. Back the following for skim. Use loads of the sticky floor protector. Often wonder if some under price work so need to rush to make a wage?
Have to agree with that, if I were to charge people an extra day just for blue gritting I would not get the work, there is always some little s**t who will do a house for fifty pence and customers do not know what the job entails all they see is he wants fifty pence to do my house you want fifty million for as far as they know the same jobTakes 5 mins to staple a tarp down...
Masking tapes for painters...just wipe as you go also easier to see margins etc...
1 coat of thick pva and your skimming in 10 minutes...
Beads and additional powder and tasks inbetween trowels...
I'd be literally thousands down a year with that palava set up!
We used to use it a lot a few years ago as hard wall went through a phase of cracking and blowing srrangely enough around the same time the eco warriors decided celcon blocks had to be more heat keeping in friendlyTbh I never used gyprime until about a year and half ago always used to over look it as it’s £80 ish a tub but having mixed different dilution of it 5-1,4-1,3-1,2-1 and pure penny finally dropped to me that it’s the king of prep , I tried a few tubs of micro gobetis and that isn’t far off gyprime for pleasure of skimming over but micro and blue grit are pigs to apply compare to gyprime ( I use a big brush from P1ss), gyprime lasts for a long time if diluted correctly and saved into bottles in van I have different dilution ratios at hand , it’s ready to skim within 10 minutes most the time on any surface, my last tub lasted nearly 2 months.
Depending on job I’d sometimes prep day before if possible, good plan in terms of rooms being ready to go
Blue grit imho I found the worst pre treatment to apply and skim over I’ve ever used though, I’d tell builder straight who is in charge of plastering and swap to my choice.
True I forgot that too mate if needed on brick work too added bonus it can control suction for light weight float coats especially hard wall , some jobs I’ve floated wall in hardwall then gave a watered down quick flick over before skimming, it’s very versatile product, even Pva has its down falls ,small blisters and air pockets , un even suction, gyprime doesn’t it’s kingWe used to use it a lot a few years ago as hard wall went through a phase of cracking and blowing srrangely enough around the same time the eco warriors decided celcon blocks had to be more heat keeping in friendly
It used to be good skimming over the hard wall, no rushing aroundTrue I forgot that too mate if needed on brick work too added bonus it can control suction for light weight float coats especially hard wall , some jobs I’ve floated wall in hardwall then gave a watered down quick flick over before skimming, it’s very versatile product, even Pva has its down falls ,small blisters and air pockets , un even suction, gyprime doesn’t it’s king
Never saw paint added, sand yes .I spoke to an old Irish fella a while back that told me they used to mix Pva , sand and paint together, paint it over everything (existing painted walls) and skim a few days later
It’s a light weight floating coat, gypsum based similar to bonding and browning, you skim it with multi finishWhat is this hard wall anyway? I'm sure I'll have seen it, but I call it something else. Bit like that Cat face thing that came up the other day.
Just floating over celcon or bricks it does concrete as well but takes a while to go off on low suction backgroundsWhat do you use it for? Why is it better than bonding or browning?
You will have to give an old git a bit of Lee way here but what’s s&cNever seen it, but my experience is more to do with general building/jobbing than wider experience of plastering, so I've only seen dot and dab,or baton and board or float and set for going over brick and block.
I've heard of one coat but I know everyone says it's s**t.
Why use hard wall instead of s&c,pretty much because you can mix it with a drill?
What a thick f**k I am sorry about that, there is no waiting for three days or more before you can scrim it on high suction blocks you set the same day, plus it’s lighter than sand and cementSand and cement.
That should be scim not scrimWhat a thick f**k I am sorry about that, there is no waiting for three days or more before you can scrim it on high suction blocks you set the same day, plus it’s lighter than sand and cement
I really don't understand what you're on about?Tbh I never used gyprime until about a year and half ago always used to over look it as it’s £80 ish a tub but having mixed different dilution of it 5-1,4-1,3-1,2-1 and pure, penny finally dropped to me that it’s the king of prep , I tried a few tubs of micro gobetis and that isn’t far off gyprime for pleasure of skimming over but micro and blue grit are pigs to apply compare to gyprime ( I use a big brush from P1ss), gyprime lasts for a long time if diluted correctly and saved into bottles in van I have different dilution ratios at hand , it’s ready to skim within 10 minutes most the time on any surface, my last tub lasted nearly 2 months.
I think he was picking up on something I said earlier when I got gyprime confused with blue grit when saying about watering it downI really don't understand what you're on about?
Gypprime isn't a replacement product for Blue Grit, PVA or Microgobetis, it does a different job.
Thistle Bond-it would be a more comparable product surely?
I’d use gyprime instead, can be used for pretreatment of surface for skimming too not just suction control for blocks mateI really don't understand what you're on about?
