Board finish
The only differance, ive noticed is that board finish goes of a bit quicker. handy in cold temps.
Not realy mate only you have to sponge one coat or MP 75 what ever you want to call it but Multi you dont, end of.
The reason is that gypsum plaster replaced lime plaster which was breathable and gypsum is not naturally breathable and if not done properly you could have problems with mould etc after time. The reason for 2 coats is that you apply one coat and when it is about to go off you apply the second coat. As the first coat is drying the drying out process makes the second coat porous and more breathable and the trowel can give a smooth finish without glazing the plaster. If the plaster is glazed you will have problems.
So Brendan would you like to start again on you're experiences of one coat plaster you tosser
I had wondered about your name.
If you read the posts you would know i only do lime
plastering and also on that thread if you read it you would see what architects have written about moulds etc. Perhaps you are more qualified than architects to speak on such matters but somehow I doubt it. You certainly know jack s"""t about lime plastering.
The going rate for skimming was 20 Euros during the boom.
Brendan it was a draft around velux windows third post in youre slagging the plasterer off and blaming him .......then you're telling me it was because it was one coated .....I await you're reply lol
You must be blind as well.
Otherwise you would see that there was not even one coat on because there is a gap between the velux and where the plaster ends that a mouse could get in.
What if it was tape jointed mate?
A funny question for someone claiming to be a plasterer????. Over here we always put a tape where a plaster board meets timber or PVC.
I have to log out now but I will be back again tomorrow evening. Good night all
Ha ha touché you ******* t**t look forward to abusing you tomorrow hope you choke in you're own vomit you big time Kunt :RpS_lol:
Rock sorry I disagree mate I've found you get more time with the second coat because the first coat takes most of the suction
Currier you're going round in circles and tbh you haven't got a ******* clue
Bod I hope you had a good days feeshing
Luscious can you tell us all the difference that is sponging one coat plasters and multi finish
Fair enough you can think what you like - what exeactlynhave I not got a clue about?
Was just trying to explain and be helpful. **** this s**t, think I'll keep my mouth shut in future.
Well done you are making this forum shite for new members.
No i cant mate, does anyone know what BGs stance on this is.
And a pleasant evening to you. I am quiet healthy and thank you for your concern. I just had a nice stake with onions mushrooms and mashed potatoes after a pleasant day at work.
You sold that well mate .........it covers plaster in fat lol
from the knauf web site
Application method
Before starting to spray Knauf MP75,
make sure all beads are cut and bedded
in using Knauf MP75. Ensure that all wall
areas are clean and dry, and add pretreatment
if required.
Spray Knauf MP75 in overlapping
bands at the desired thickness (usually
11-13mm and up to 20mm) and then
use an aluminium feather edge to rule
the plaster flat.
Once flat, leave Knauf MP75 for
approximately 75 minutes to allow for
the initial set to take place.
The initial set time may vary depending on the level
of suction from the background.
After the initial set, use a small
aluminium feather edge to apply a
second rule and to remove any
imperfections from the surface.
Now leave the plaster for approximately
20 minutes more or use the “Touch Testâ€￾
– touch the plaster surface to check it
does not stick to your fingers and resists
finger print impressions.
Using a spatula, open the surface to
Using water and a sponge float, bring
the of the plaster to the surface.
Leave for a further 10-20 minutes or use
the “Touch Testâ€￾ again.
Using a quality steel trowel, push the
plaster FATS back into the plaster to give
that all important hard and smooth finish.
See it is called FAT :RpS_biggrin:
Can someone please explain what's going on here, 1 coat 2 coat sponging etc?
My skimming has always been two coats in any hit what's the beef on here?
No beef at all I just read that and it mention fats which is what I said at the time and spunky said that I didn't have a clue what I was talking about when in fact I did.
