OldPlasterGuy
Hi, I need to put plasterboard over an old ceiling but I can't tell where the joists are to screw into, so any tips on the best way to do it?
Hammer
The ceiling.What do i hammer?
The ceiling.
The places where the hammer doesn't make a hole are the joists.
Use the force Luke, use the force.Hi, I need to put plasterboard over an old ceiling but I can't tell where the joists are to screw into, so any tips on the best way to do it?
Oh i see.
I have been using a drill to drill either side of the joist to mark them out but it's difficult to do from above as a lot of it's boarded over, and it's filled with loose insulation, which keeps falling through. I can do it from below but im worried i may hit a pipe or cable.
it's also a very old ceiling so if i start bashing it with a hammer it might come down.
Find one then every 40cm be abother
Watch out for joins so do both sides ceiling make sure matches
Do you intend to get a plasterer to skim the ceiling? Because he'll overboard it in about ten minutes for not very many pounds and save you all the trouble.
Or 16". What's all this 40cm anyway, you cock eyed c**t? It's 400 mm. FOUR HUNDRED MILLIMETRES!!!!!!!
People like you make me sick. Worked with a fella last year who couldn't work a tape. Could never make head nor tail of any measurement that he shouted down.
One metre, six inches, twenty millimteres and two.
What?
Two what?
Then down he'd climb and show me what he meant on the tape.
In millimeteres, you stupid c**t.
Okay, Okay. No need to get angry.
One meter eight.
What?
One metre and eight.
Eight fuckign what? One point eight? One metere 8 mm? What?
Inches. One metre eight inches.
Another nice story steven. Might read it to be toddler to get him to sleep
A little tip when you start boarding start in the middle and work out.![]()
I bet it was him that "trained" you.
Listen, you sausage. Just because you got booted off the painters forum doesn’t mean your a spread, you slag. Take your armless body to the dung
Why ?Hi, I need to put plasterboard over an old ceiling but I can't tell where the joists are to screw into, so any tips on the best way to do it?
I’m trying to put the YouTube clip up but I ain’t got a f**k**g clue how to! LolTj dillashaw lol
Tj dillashaw lol
