32kg/M2 not skimmed 22 skimmedBricks slips on plasterboard.. overskim first or use stronger fibreboard... These bricks are heavy... Anyone done slips with no issues.. thanks in advanceView attachment 53908
did you not use spacers?i have fitted brick slips on an EWI background using tile adhesive. we had to go over all the previous days work each day to correct any that had slipped.
Iv done it a few times and used tile adhesive with 10mm dowels as spacers and pointed up
[/QUOrapid set adhesive
I used strips of 9mm ply as spacers for joints, works a treat.no spacers.
they wanted large joints like brickwork. for the pointing we run a half inch paint brush along the base coat to give the joints a recessed look. the pointing was done after every metre of fitted slips.
the work was done on a block of flats in Hertford.
Do they not swell with the moisture and tight to get outI used strips of 9mm ply as spacers for joints, works a treat.
Dowels are better and cheaperDo they not swell with the moisture and tight to get out
Not enough to worry a normal person.Do they not swell with the moisture and tight to get out
Not if you have offcuts out of a skip. I like the dowel idea though.Dowels are better and cheaper
Hi guys
If you have heavier slips, tiles or natural stone... Knauf Aquapanel Cement boards can take heavier loads
Knauf Aquapanel Indoor
When fitted to acoustic C Studs at 600mm centres - up to 50 kg / m2
Check frame performance (stud does not buckle due to weight and height of wall) and usually at max 300mm centres - prime the board and it can take up to 120 kg / m2
Knauf Aquapanel Outdoor
Recommend that the outdoor board is taped and jointed and has a min 5 mm layer of basecoat and mesh applied - this gives the weatherproof later behind the adhesive, binds all the boards together and reduces the risk of boards opening at joints if and when the structure moves or settles
When fitted to framework suitable for the load and battens / supports at 600mm centres - up to 40 kg / m2
Bring the battens / supports to 300mm centres (ensure they are still fixed back to the actual structural framework, crossed battening or similar with suitable fixings first the loads) - up to 60 kg /m2
refer to Knauf for system specs and assistance
[email protected]
Or get in touch with me via DM or [email protected]
07918 766577
Richard Lord
Knauf
Aquapanel Technical Manager
Lucky guess lolWell said bof
gypsum boards have a maximum bonded tile Weight limit up to 32 kg / m2....
there are specified construction and finishing Conditions to achieve this also - so take advice from your board supplier of choice
What are the regs for fixing above 3 Mtrs external?Always make sure you use suitable tile adhesive for the sub-straight board and tile, slip, natural stone. Also, make sure it is suitable for the final environment... not all tile adhesives are suitable for external use!!
Also, there are rules for fitting bonded only tiles, slips and natural stone above 3 mtrs high - especially in outdoor applications...
Good Luck!!
Does it only hurt your Swede if it happens outside?mechanical fixings required I believe. You wouldn’t want a heavy tile falling on your bonce!
Stop with the long words, do you know the regs or do you just fancy a chat?obviously not, but it would be rare ina domestic settin to have tiles above that height, plus outside I’m guessing the weather can cause issues with longevity.
Not my area of expertise.... but, if the tile is above a specific size they need to have a form of mechanical fix back to the substructure or frame.... various options to achieve this, if the supplier is reputable they will advise
Could some special tape with holes in it work for this purpose?
(asking for a friend)
Eh....?
am I not in on this joke...?
if you have a potential solution, explaining it a bit better...
Sorry.
It's a running joke on TPF, not aimed at you, but at tapit.
