Bubbles, lines appearing and plaster tearing when applying to walls.
If it is 2 coat work ie float and set the bubbles could be due to the backing plaster being too wet ie not properly set and the lines again if it is 2 coat work make sure you aint got the nails in your devil float set too deep cos this will cause grinning which will appear as dark lines in the finishing coat when set. if it aint 2 coat work pictures of substraight and finish coat being applied would help us help you :RpS_thumbup:
