Can this be dabbed onto?
Rob6737
Been to look at a job, customer saying they want this wall boarded and skimmed but I’ve not dabbed onto this before. I’d appreciate any help. Thanks
If it can be dabbed on to, it should have a mesh on the plastic membrane. They make 2 types. The type with mesh can be dabbed, the type without can't and needs a timber frame building in front of it. If mesh and dabbing you shouldn't dab anything onto the fixing pegs. Although it seems a good idea as they would be the strongest point this is wrong. The whole plastic membrane stops damp and moisture. When drilled to insert a plastic peg the membrane now has a hole. If anywhere now has a weak point and a possibility to fail it would be the peg area. So all adhesive should be put inbetween pegs. As long as the membrane has been installed correctly with correct spacing between fixing (this one looks to be right) then it will hold the weight of adhesive and board no problem
Tend to agree with you there about not dabbing onto the plugs but I got some Permagard pb2 and they say you should dab onto the plugs to make it more rigid
