you can get a low epansive foam to stick them with some people cant get on with it but i find it OK.
nelly, give the old 'concrete screws' a go...
Link Removed
stick your kingspan to the wall with gripfill or silicon temporarily, butt the joints up and run some gaffer tape over the join...
use some 25x50 treated timber @ 400 ctrs and drill straight through the timber and the cellotex with a 6mm long series sds bit and just wind the screws in, its quick as f'ck mate...
plus, you get a 25mm air gap, you can run your cables in it, you dont need a vapour barrier cos youve taped the joints up and you dont need to use vapour check board for the same reason...
ive just done half a house like this cos it was fire damaged, i couldnt dab owt to it and i absolutely flew round it...
if your gonna use ply you lose your air gap, it'll be silly expensive and youll (or your spark will) have all the fun in the world trying to chop sockets into it...
i'd stick with the 'roofing lath' mate...
although if you want a firmer wall with no air gap, theres nothing to stop you using 25mm cellotex on the wall, batten over and fill the gaps between the battens with more 25mm cellotex?
that said and thinking on a bit mate,
if youve got things like kitchen units or sanitary ware to hang on the wall then the ply is a good idea...
used to do that when the 'document m' stuff went mad a few years ago for disable bogs etc.... gives you something to fix all the grabrails etc to....
it just messes you up for fixing electric, but if you surface fix - end of problem...
