Stylesh1995
Carlite finish (red bag) is it good? Better than multi? And can you use it on plasterboard?
Why wouldnt you just use multi?Yeah I’ve heard some good reviews. Just wanted to double check before I go ordering a pallet. Don’t want to get caught out
Probably because there is a national shortage of multi atm?Why wouldnt you just use multi?
Then why are you f**k**g about? Buy carlite while you canProbably because there is a national shortage of multi atm?
Used it the other week and it’s nicer to work with than multiProbably because there is a national shortage of multi atm?
Try it see what hapoensCan you add bonding to it if needed?
Happens lolTry it see what hapoens
Cheers mateUsed it the other week and it’s nicer to work with than multi
They're both gypsum based so cant see why it would cause any harm doing a magic mixIt says on the bag not to add chemicals just wondered if it also means dont add backing coats
By chemicals does it mean extratime and them productsIt says on the bag not to add chemicals just wondered if it also means dont add backing coats
Does it say on a bag of multi that you can add bonding then? LolIt says on the bag not to add chemicals just wondered if it also means dont add backing coats
Exactly!
Exactly!
What chemicals you concerned about adding mate?But it also doesnt say to not add any chemicals where as carlite does
Surely adding gypsum to gypsum isn't adding chemicalsBut it also doesnt say to not add any chemicals where as carlite does
Bonding?
Yeh I reckon no probs ,went on top of catlitte with multi today as ran out fir 2nd coatCan you add bonding to it if needed?
