Cavity wall tie replacement...
Did the surveyor remove bricks to check the ties because if he hasn’t there’s no way of knowing if there rusting.Get another surveyor out to check them
No he located them with a metal detector and then chiseled most of the joint with an sds chisel followed by a hand chisel to locate the tie.
