Potentially, dosing down the walls with water ( as we have done in the past) and as you prob do, is still the most ecomonic answer.
To be honest Mark I've never hosed a Celcon or Thermalite wall down before rendering it. I don't lay on big areas before ruling of though, I prefer to use screeds and then drop down the wall in stages laying on the full depth in one coat (11mm) and only put a coat right over a wall if there is to much thickness for just the one.
Cant you just give it a quick blast to seal it then go over the top?
its worth sealing the walls to make your job less stressfull. render or plaster drying to fast is the hardest part of our trade
blones i got glenn a colouring book for xmas a few years ago you should of seen his face when he opened his present then he called me a ****that's right don't listen to me.
you cant use an accellerator with a leccy machine
and don't seal walls to make life easier
i'm off to do some coloring in now wiv me crayons
who betty, and you welsh inbreds lost the rugby, back to the hills chasing sheep for the welsh rugby team lol
cpi is ok but sounds like nuts and bolts going through the machine
