tapit
Better read your books, i am a master carpenter mate.wrong again a quirk is were a bullnose corner returns back to sqaure
sorry I missed c**t outNo need to call him that.
a masterbaterBetter read your books, i am a master carpenter mate.
F*****g Richard head I would sayRichard or Karen?
its just a warm up m8Save a bit till Friday night.
sad
Not bad for a Wednesday Norm. So you form a ‘vee’ and any crack that could form is in the valley so you don’t see it? Shadow gap so to speak
Not really a crack, you know the plaster will pull back a bit from the bead just leaves a small gap rather than a hairline crack from metal over wooden bead.Not bad for a Wednesday Norm. So you form a ‘vee’ and any crack that could form is in the valley so you don’t see it? Shadow gap so to speak
Take them out.they crack,always.I.ve scrimmed loads and never had come back
But if you scrim the joint it also eliminates the chance of cracking, the same as the joint between plasterboard.let me educate you boys if u plaster up to timber it will crack that's the reason for the v joint which by the way is formed by using the head of a 5inch oval nail so the crack is hidden and don't show
I had a wooden beads crack few years ago went back and sorted it. Since then I have always cut them out, stick metals beads on with bonding, let them set properly and fill them out.Any body had come back from doing bottom meter in sand and cement in to plasterboard even after scrimming joint.
Also on wooden beads. I.ve never had comeback after scrimming bead but kid who's doing job with me next week says he has so wants to pull em of.
what a fkin faffPVA the bead first, bead on, scrim down both sides, bit of bonding on top of scrim then skim it. Never had a bead crack and I always say to the customer if it cracks let me know and I'll pop back and fix it.
if its a cheap shite hole property ok /but if a quality old house the wood beads should staywhat a fkin faff
by the time ye fked about doing that you might as well just cut the fker out and hardwall it up and do the fkin job properly fkin chancers forum on here
sucpence is killing me
PM me lolFed up of giving tips away for free in public bit
give me your bank detailsFed up of giving tips away for free in public bit
f**k him .Dom littlewood is watching you!!
took the words out my mouth jonf**k him .
