yes just pinch a bit out between your thumb and forfinger but im talking about casting plaster you would have to experiment with what your using but do not over dose or u will stop the set for to longIts normally about 5 black buckets to about 4 and half bags.so do I just put a little bit in each black bucket mate
what f**k**g key ?View attachment 49337£50 for a key
It’s a term used in cocaine abuse dip a key in the Bag and snort off the key know as keying itwhat f**k**g key ?
this old c**ts learning all the timeIt’s a term used in cocaine abuse dip a key in the Bag and snort off the key know as keying it![]()
Probably not something you want to know but if it ever comes up as a question on who wants to be a millionaire! Don’t forget your mate smootherthis old c**ts learning all the time
when you can tell me whats in 90 percent then ill give you some spec bruv innitProbably not something you want to know but if it ever comes up as a question on who wants to be a millionaire! Don’t forget your mate smoother![]()
Agree but light soy not dark as this can cause molecular coagulation which is common
sorry missed that but I wont forget u will buy your dog a bone as wellProbably not something you want to know but if it ever comes up as a question on who wants to be a millionaire! Don’t forget your mate smoother![]()
Cream of tar tar did use to work but the manufacturer changed a couple of additives to make the chemical reaction of the powder more powerful once water was added that's why theres only a medium window of opportunity of working with the multifinish or board finish before setting starts to occur cream of tar tar doesn't have that affect of slowing it down anymore your best using plain flour as it reacts to the hemihydrate in the skim slowing the process down a couple of handfuls of plain flour in the mix will give you an extra 35mins per 25kg bag
Added two handfuls of flour in the mix for the first coat, worked a treat mate, advice really appreciated.Cream of tar tar did use to work but the manufacturer changed a couple of additives to make the chemical reaction of the powder more powerful once water was added that's why theres only a medium window of opportunity of working with the multifinish or board finish before setting starts to occur cream of tar tar doesn't have that affect of slowing it down anymore your best using plain flour as it reacts to the hemihydrate in the skim slowing the process down a couple of handfuls of plain flour in the mix will give you an extra 35mins per 25kg bag
None available anywhere needed it asap, was advised to try two handfuls of flour per bag and it worked a treat, problem solved.Link Removed
Link Removed
Self-raising or plain?None available anywhere needed it asap, was advised to try two handfuls of flour per bag and it worked a treat, problem solved.
WTF just happened???![]()
its called tri sodium citrate... f**k knows where you buy it from but it works a treat, we had some well out of date bags of some one coat shizzle from the bricomarche in france and it hung right back... teaspoon in a mix
my wife buys it on line for making a lime drink. maybe 250g bag. I've got some year old multi at the back of the shed- I'll give it a test for a laugh.its called tri sodium citrate... f**k knows where you buy it from but it works a treat, we had some well out of date bags of some one coat shizzle from the bricomarche in france and it hung right back... teaspoon in a mix
I use cream of tar tar, it works great, specially when I accidentally put a little too much in, and the stuff didn't set for three hours
never used it but have used extra time a few years back on my first 2 bagger ceiling. Worked really well. Don’t worry so much now. I reckon plaster can smell fear and the less I worry about it pulling in too quick, the better I get on.
Very true! I'd like to give extratime a go, see how it is. I'm constantly finding the plaster flash setting - the water here is very hard (wants a fight when it comes out the tap), when I added the tar tar, the plaster started to settle down better.
Up north, the water is very soft - never have an issue with plastering at all up there
