D42 clamp r&s setup?
goody
Wanna have a fiddle with me new d42 clamp r&s today. Can somebody explain how to set it up with the pressure tester. Is it a bit hit and miss getting it to ten bar first of all or is there a number of turns of the middle nut after initial bite to get roughly around ten then the other two to follow? Cheers chaps
what i do Darren is tighten up the middle bolt until its pinch well and then a half a turn, bring the rest of the bolts until pinched and then test, if it needs more tightening then do the middle a couple of turn and then the top and bottom. You also need to leave the pressure for a couple of min to see if it drops away.
havnt used d42 for a while but used to wind clamp up so its 50mm apart at its widest point , that used to be roughly there then tweek it with tester
