Damp patch on newly plastered wall
AndrewLM
Hi all,
I have had my wall replastered approximately 2 months ago and I have this patch that persists.
I have kept the room well ventilated and have recently had the heating on to try and encourage the dark area to dry out (although it is not particularly damp).
I have been told to gently hairdry the area which seems to work slightly before reverting back.
Does anyone have any idea of the cause of this and the next steps I should take?
  • Damp patch on newly plastered wall
Hi all,
ye got bigger problems pal that skim job looks shiite...you've been Nathed.
Hi guys, thanks for your comments.
I may have been done over but if someone could suggest what I can actually do to fix the issue that would really be appreciated.
Hi all,
@John j
What is the other side of that area?
Why did the job need doing?
Had the original plaster blown due to water ingress that is still ingressing?
Hi all,
1 have a look outside if thers a problem
2 if ther is sort it out
3 hack wet bit out leave it to dry
4 fill back and over skim again but a nicer job
Or hack the place scratch coat and insolated boards
Hi all,
Thank you for your feedback.
As a bit of background, I had a damp patch on the far right side of the area that has been replastered. I investigated the outside and found that a guttering problem had led to water eroding the brickwork and I got that fixed.
I then ripped the wallpaper off to expose the old damaged plasterwork. The plasterer then removed the plaster from the brickwork (pictured) and then replastered.
The damp patch that I previously had is nowhere near where this dark staining currently is.
I would really appreciate your thoughts.
Hi all,
My thoughts are I’m off Friday till Tuesday and I can’t wait to get pissed up!
Wish me luck!
Hi all,
Chuck flour at it!???
sorry…wrong damp spot!
