Hello everyone,
Hoping you can spread some light on my problems ? just had a wall re plastered the damp has come back through and spread like wild fire.even onto walls that were never damp.three days after the damp appeared its starting to shrink.....i was told by someone that the plaster may all have to come off back to brickwork !!
its a grade 2 listed cottage ive owned for 20 years and its a mystery.The wall where the problem started always seems to blow the plaster out in certain areas after some time ,what would be the best course of action so i dont keep getting hassle from the same area of damp.And in another room my friend told me to put one coat damp seal on a 4 x 2 damp patch and the damp is spreading should i take the plaster off ? do i need vents fitting ...I would really appreciate any help or advice you can give me ....also should the plaster have been a lime plaster to let the walls breath ?
The writing below is from a google search not my writing....
The solution is to remove render and let the walls dry out. If brickwork is damaged and needs repair or replacement, it should be done with lime mortar. If it is proposed to re-render, you must always uselime render, which can breathe freely, and allows trapped moisture to escape.
