jamesthefirst
Did it state in the estimate they would use sand / cement or renovating plaster?
Sorry to say you've been robbed sand and cement may not be an option either might be looking at lime mortar, the sand and cement may of been the original problem any pics before the work?its a stone wall and i asked for a re plaster where the damp had pulled the plaster off....and im in norfolk and he suggested about going half way up the wall ?
Dryzone do a pre bagged render in fact 2. The 2nd has a high lime content for surfaces you have and can be skimmed with normal multi finish. I would apply an anti sulphate prior to this if I were youHi marshy.... There are pictures on page 1 of this post just after he re skimmed the wall...you can see the damp ....ive just pulled a lot of plaster off this afternoon and the wall where the damp patches were are very damp... im not sure wether to pull all the grey mix which i presume to be sand and cement ? right back to the original walls ??
Exactly, the biggest load of b*ll***s in the industry.https://www.heritage-house.org/managing-damp-in-old-buildings.html according to who ever this is rising damp is complete ----shite ?
If you haven't done any, doesn't mean it's not thereExactly, the biggest load of b*ll***s in the industry.
Agree. Injection should be the first thing before any waterproof render!Hi mark,in my opinion what you need to do is ,take skirts off,strip the wall upto a metre in height , have your wall injected with a good damp cream replasted with sand and cement with waterproofer and a salt inhibitor added to the mix , taking care not to bridge damp by covering the injection holes ,put a finish coat of plaster on then replace your skirts job should be done .the problem is they have used a gypsum based product which will attract moisture.as it is a graded building you may want to use traditional methods as you have already looked at through google I see , up to you.
In order to tell you were it's coming from rising or penetrating damp etc if you could post pics of both sides of the wall and surrounding areas this would help.
Prove itRising damp is a real thing ! You know it is .....
Explain what this cream is going to do in this stone wall and where your gonna put the creamHi mark,in my opinion what you need to do is ,take skirts off,strip the wall upto a metre in height , have your wall injected with a good damp cream replasted with sand and cement with waterproofer and a salt inhibitor added to the mix , taking care not to bridge damp by covering the injection holes ,put a finish coat of plaster on then replace your skirts job should be done .the problem is they have used a gypsum based product which will attract moisture.as it is a graded building you may want to use traditional methods as you have already looked at through google I see , up to you.
No magician shows his tricksProve it![]()
I know he has got damp and it's because the wrong plaster has been used its that simple, answer the question I asked would be nice, if your doing this day in day out your ripping people off Coz what you advised to do is a load of b*ll***s. Any proof of rising damp seeing as you do this day in day out?Fukin hell Flynn , the man has damp are you blind!!!! There is preventable measures on the market. Do what the fek you want pal your house , just trying to help. I deal with this day in day out cover all bases like I said and you will eradicate it! Ultimately am not there so can't really tell you much more than I have , hope you get it sorted....
Any pics of the outside?Im confused ? whos saying what FFS !!
ill post someAny pics of the outside?
I'm jot arguing with you it was a simple question why do you think in other countries they don't put a dpc in? Have you ever found rising damp and any pics? Coz me and others on here don't believe it exists. No need to see your arse and call me names xxSound , you answer this when people build houses why do they put a dpc in? Same as when you put concrete in a floor why do they put a membrane in? Listen the fella came on for advice all I have seen from you is negative comments in the last two weeks nothing less than an internet troll!give ur advice and shut the fuk up!!!
So you've been here two weeks and that's it? Maybe settle in a bit better then you might get a feel for the place, then you may actually fall in love with meSound , you answer this when people build houses why do they put a dpc in? Same as when you put concrete in a floor why do they put a membrane in? Listen the fella came on for advice all I have seen from you is negative comments in the last two weeks nothing less than an internet troll!give ur advice and shut the fuk up!!!
Just ignore him. Think he got thrown off UKSpreads for doing something similar. That was a plastering site, by the way, not porno.Sound , you answer this when people build houses why do they put a dpc in? Same as when you put concrete in a floor why do they put a membrane in? Listen the fella came on for advice all I have seen from you is negative comments in the last two weeks nothing less than an internet troll!give ur advice and shut the fuk up!!!
Ok flynnman a bit longer than two weeks if you look not dedicated a lot of time tho, am not here to cause friction either just to help out were I can and have the crack as it comes maybe learn a few things I don't know, everyday is a school day I don't know it all after 20 years and the game is evolving every day but on this subject there is not much you can teach me ...... no such thing as rising dampSo you've been here two weeks and that's it? Maybe settle in a bit better then you might get a feel for the place, then you may actually fall in love with me![]()
