stuart23
DefinitelyYes and you would expect the price to reflect it?
fixedI also got the impression we were speaking with a female
Lol it would be great if the op went round and took more pictures for us all , I've got my money on this one being a property built between 1854 and 1910 , probably the best built buildings this country has ever made far better than the new build I went round to last week where they could hear the neighbors shagging,there is a family in a village near me ( Dunton) who bought their dream 4 bed detached house or so they thought, it has had to be pulled down because it was unsafe after an absolute bodge, this wasn't a new property either, they are currently living on the site in a caravan with absolutely no legal avenues to go down.
Now I'm not saying this is the case here but bad work has shown up in a short space of time, what else have they hidden or done wrong ?
Seriously stop talking s**t, I don't know if this is coz your brother is a surveyor or you are completely stupid, but the work they intend doing is a bodge not correct unless you know something I don't? And it doesn't take much to satisfy a surveyor believe me coz like @gps says the report is worthless.Lol it would be great if the op went round and took more pictures for us all , I've got my money on this one being a property built between 1854 and 1910 , probably the best built buildings this country has ever made far better than the new build I went round to last week where they could hear the neighbors shagging,
And Flynny the £5000 was when negotiating the for sale price not the tiny bit of correct work taking place in there now before they move in , obviously it's getting sorted so they satisfy the reports off the survey guy so it's all good for this op
Correction of the bodged work I meant mate if they are ripping all the boards off I agree it shouldn't be dabbed plasterboard I'm not completely stupid believe it or notSeriously stop talking s**t, I don't know if this is coz your brother is a surveyor or you are completely stupid, but the work they intend doing is a bodge not correct unless you know something I don't? And it doesn't take much to satisfy a surveyor believe me coz like @gps says the report is worthless.
Don't believe itCorrection of the bodged work I meant mate if they are ripping all the boards off I agree it shouldn't be dabbed plasterboard I'm not completely stupid believe it or not
Or hardwall a lot do that round here even though me personally thinks it's s**tWhat if it was membraned then dabbed, surely that would be ok as that's what we do for damp companies.
It's only hiding the problem the damp will go elsewhere. I was on a job the other month where they had a ginnel I was using to access the flat above and the house to the right the bricks had perished and the salts were all over it thy had the membrane fitted but it was f**k**g the outside of the house up lolWhat if it was membraned then dabbed, surely that would be ok as that's what we do for damp companies.
It seems they have put a membrane behind. To be clear this room was full plastered then they have taken off section where the damp came through, put a membrane behind those sections and then plastered on top again. They haven't put a membrane behind the whole wall, just the damp bits they took off. Also the main section they have done is on an internal wall. This is a ground floor flatWhat if it was membraned then dabbed, surely that would be ok as that's what we do for damp companies.
Who told you this or have you seen it? Get some pics up of the whole house and the external, if you want honest opinions with no bullshit. But I've got a feeling your gonna do what @gps has just said so when you come back for advise on how to fix it in October/November we will not hold it against you .......,,,,, that was a lie, we will take the piss for a bit but still help you we will just blame @Vincey lolIt seems they have put a membrane behind. To be clear this room was full plastered then they have taken off section where the damp came through, put a membrane behind those sections and then plastered on top again. They haven't put a membrane behind the whole wall, just the damp bits they took off. Also the main section they have done is on an internal wall. This is a ground floor flat
It is a nice gaff I can see why you fell in love with it, knew it was an old gaff firstly there is an issue with damp and unless you source the problem it will return or move somewhere else. What is behind the walls they have patched? Is that a chimney that has been removed? Plasterboard should not be anywhere near them walls in my opinion and where they have removed the chimney I would be very concerned if it is being supported above going off the work they have done.We aren't making any desicions today either way - that's for sure. I don't have access to the property so can't take any pictures . The ones I took of the inside were actually taken from the outside. I thought that the blue lining behind the plaster you could see in the initial photo I posted (inserted again below for ease) was a membrane lining? Am I wrong?
I also don't have any external photos of my own but see the link below for the advert
https://www.rightmove.co.uk/property-for-sale/property-47681145.html
Bloody hell thats cheap
Right where the down pipe is from the gutter, Flynny might even agree with me on thisSorry behind the plaster board I meant - they took off sections of plaster board and put some blue sheet behind, but just the damp bits not the full plasterboard.
Can I ask why old walls like this shouldn't have plasterboard and what is the alternative? Thanks
That is an old chimney there also don't know when the fireplace was removed.
@Vincey yes the room with the most work happening in it is the room you can see on the right hand side of the front door
Flnny
These type of properties should not be dabbed because they are solid walls which get cold and cause cold spots, they should be be done with like for like ie lime sand mortar.Sorry behind the plaster board I meant - they took off sections of plaster board and put some blue sheet behind, but just the damp bits not the full plasterboard.
Flnny
post the pic your looking atRight where the down pipe is from the gutter, Flynny might even agree with me on this
I think Flynny has gone to the gym now but he'll be back tonight so check in later just confirm what he wants but the down pipe in the photo above looks like it's had water pissing out of it from the top floor which we can see on the stone wall at the bottom on ground it looks like a manhole cover and the ground slabs are pointing towards the house , tbh I think that's what Flynny wants to seeThanks for all your feedback so far guys, it's really appreciated. Let me know what aspects of the external building you want me to take closer photos off and I'll go round this evening or the weekend. It was absolutely pishing down this morning but has cleared up for now - but it's Scotland, the rain won't be far away
Ps ignore gps
That makes senseSo you had a surveyor out who probably mentioned to the vendor that they have damp, now your mortgage firm will ask you to carry out damp proofing to release the mortgage, simple, so the vendor went ahead and started doing it hopefully done by a firm who's guarantee will be accepted by your mortgage provider, therefore you can't knock the price down. Heyho presto all is sorted, even if you pull out and the next purchaser comes along and having a survey done the vendor can show the guarantee to the surveyor that it's been done recently therefore mortgage firm will be happy to lend.
Just a thought, is the guarantee attached to the property, current owner or the person who paid for the work to be done? They are usually worthless anyway but thought I would askThat makes sense
