You'll be surprised at how much coverage you can get with your first coat from a 1 bag mix,
Not realy a surprise its about 10m!
Its only 75 ltr!!!
Give over. It’s 150...I say it’s 150 litre!!
That's how we used to control the set . Mixing up in a yellow builders bucket about half a bag at a time , you would have the spot board loaded out and use the finish in the order that it was mixed so stuff was not all going off at the same time . But that was back when you had a labourer who only laboured and plasterers only plastered .Sorry but it's true. I don't want a whole move going off at the same time.
We simply mixed in a large dustbin and put it on , crazy but it works ,That's how we used to control the set . Mixing up in a yellow builders bucket about half a bag at a time , you would have the spot board loaded out and use the finish in the order that it was mixed so stuff was not all going off at the same time . But that was back when you had a labourer who only laboured and plasterers only plastered .
That's why everyone is physically fookked by the time there 50 these days .We simply mixed in a large dustbin and put it on , crazy but it works ,
Yep spend their whole working lives chasing their arses. I've seen it so many times.That's why everyone is physically fookked by the time there 50 these days .
Flexi tub 150 ltr photo please
I got bought one as a gift? Was going to send it back and get the mega mixer as my ibenstock seemed like it was on its way out after 10years. It’s good on domestics Mix outside so no mess in house and more space to work, just put it in back of van so don’t go walking no messing about moving Tranny or 110 lead. When we’re rendering just move it lift to lift to knock up on scaffold by bosh. We’re on some new builds now with no electric just yet so it’ saves having the genny running. Only thing I would say is paddle supplied is pretty big so it does splash if you ain’t knocking much gear up do it in a smaller bucket to suit. We made own paddle, knocks up in no time , no splashing just pulls right down. Dab, hardwall, basecoat, finish
You are from the new school of plastering . A few of us are from a time when you had every room planked out for skimming ceilings and you had a mix just to put the scrims on . Plenty were still mixing with a stick and podger in 86 when i started and you wouldn't want to be mixing a bag or two in one go like that . We did have labourers and as an apprentice you would muck in and do all the donkey work as well as trying to learn . Times have change a lot some for good and some not so good . IMO.Yeah the paddle supplied is numb I switched it straight away when I saw it.
Can't belive these less than bag mixes you must have a labourer coz I could not be f**k*d having to stop and mix all the time especially on a big ceiling when stilts are on
I had a whisk, but carried on using a stick and plodger out of choice for many years. I used to labour on myself float and set. Hod my own gear in, mix and lay floor screeds, so mixing a bit of skim up by hand was no bother.You are from the new school of plastering . A few of us are from a time when you had every room planked out for skimming ceilings and you had a mix just to put the scrims on . Plenty were still mixing with a stick and podger in 86 when i started and you wouldn't want to be mixing a bag or two in one go like that . We did have labourers and as an apprentice you would muck in and do all the donkey work as well as trying to learn . Times have change a lot some for good and some not so good . IMO.
Your body must be fooked or you was a very fit man in your day, fair play to u , how come you worked on your own ?I had a whisk, but carried on using a stick and plodger out of choice for many years. I used to labour on myself float and set. Hod my own gear in, mix and lay floor screeds, so mixing a bit of skim up by hand was no bother.
That’s a long storyYour body must be fooked or you was a very fit man in your day, fair play to u , how come you worked on your own ?
Yes I was very fit. Although I'm well overweight now I'm still in great working order.Your body must be fooked or you was a very fit man in your day, fair play to u , how come you worked on your own ?
IF i had to mix anything by hand now i would go home .Plenty were still mixing like that well into the 90s aswell.
And in a bath, (hoe/shovel mixing) for floating.
Conditions you.
Fannys now.
Massive contrast.
Funny enough my son actually said at the start of the week that he might give mixing up by hand a go. He's never done it before.IF i had to mix anything by hand now i would go home .
A bike crank with the teeth ground off and a length of steel gas pipe welded on for a handle was the popular choice here in Essex.Just thinking back now.
Old pram wheel plunger - i used put eml around it to mix quicker. Like a gauze.
That was our old equivalent of a massive paddle.
It was fun showing the young lads the technique, anything you learn when your young you never forget!A bike crank with the teeth ground off and a length of steel gas pipe welded on for a handle was the popular choice here in Essex.
Same for me but on on a thick broom handle cut down .A bike crank with the teeth ground off and a length of steel gas pipe welded on for a handle was the popular choice here in Essex.
Was lookin at these give us a review when you used it mateJust ordered the 240v dewalt mixer, anybody else use one?
Will do fella, looks a beast and very well priced....Was lookin at these give us a review when you used it mate
