Difference between Fassa KI7 and KC1?
Bullsh*t KI7 one of the best renders especially for renovation
Ki7 & ms200 jobs are having failure after failure, so much so they had to rewrite there spec's, one Render not far from you has had 12 failure's in 3 year's,
I used 12 ton off ki7 beginning of last year had nothing but problem's, after care is s**t and clueless,
Just offered a bit of advice, as I did when you was stuck for a machine an I got you one cheap, merry Christmas ya c**t
Sorry bud appreciate the lead on the machine and I just thought the comment was odd as I have used Artics of KI7 Fassa and never had any problems. Just noticed a local renderer is using lots of KC1...I've never used it and was wondering what the difference is...not much in price...maybe it floats up better?
You're asking about a product and then abusing one of the full time renderers who's willing to give you their expertise and experience?
No wonder so many members think you're a prick.
Have you ever given any helpful advice on this forum?
i think aslong as your sensible with whatever material youll be fine.
use proper primers/ baecoats for the right job.
ive never had any major failures on any system. only minor user errors
no bother, in my experience it doesn't harden off as it should,
VPI Monocal GF just as nice to work with but goes rock hard
Hi, We have a big issues with Ki7, looks like we arent on our own, whats your experience?
I haven't had a failure with it,
But just from working with it I knew it was s***, It's too soft and doesn't cure off as render should, May as well use hardwall,
On some batches I've even had topcoat being rubbed up, scratching through primer and surface of render,
You can't work the surface of it other than a quick spat, because too soft to be excessively worked,
A doorway had been cut out on a wall on a KI7 job, rather than patch up we went back to nearest corner beads, It was the easiest render I have ever removed, Just pulled the mesh and off came the mesh with render
