p warrilow
Hi Guys, was at the check out at wickes with usual load of multi, and a lad was returning the same stuff,saying it went off in 15 min flat. Bit like it used to when damp 30 years ago I guess.flash set. The date is the same as his,which is Feb 24 .So has there been a dodgy batch? I am hoping he is a walter mitty plasterer,ie he thinks he' a plasterer.
So Monday morning I will find out,unless you lot have come across a bad batch?
This stuff is so reliable,nothing like it was years ago,so I am hoping it is not going to give a soon to be pensioner a pain in the neck.
