Not surprised , always goes off quick if you leave it in a bucket for that length of time , gets pretty warm toowas out doing a homer today, went to b and q for plaster, gear set after 25 minutes in the bucket? why is going on???
What's it sat it bucket for 25mins for?was out doing a homer today, went to b and q for plaster, gear set after 25 minutes in the bucket? why is going on???
I push my beads into first coat , board Addy or bonding is good if the depth is a problemhad to use it to fit beads and had 12 to do, walls where crumbling if I tried to fix them any other way, got one wall on and that was the mix gubbed. Lesson learned now, thanks for the input, appreciated
Clout nails
Thread closed
No he didn't . Said cause walls were crumblingSaid he had to pull them out to straighten them!
Hence why your beads are always on the piss!
Thread closed part 2!
Thread closed part 4!
It's part 4 ye dee dar. Or it could just be old plaster that falls of when you try to put a nail in .Same difference will be sand & cement so clout nail will just smash off the plaster.
Leaving at best wonkey beads like 1st picture around door on your job!
Thread closed part 3!
Thread closed part 5
Unifinish is the answer
Depends on the dry lining , OK for site if you don't give a sh tHook on beads .![]()
Finally thread closed lolSaid nobody ever!!!
Have you used them , never heard of anyoneHook on beads .![]()
tend to fall offHave you used them , never heard of anyone
It's like a product designed by someone who doesn't plastertend to fall off
You talking to meScrim em on then skim em in level if ur struggling to bead a fookin angle john
No never see them in merchants.Have you used them , never heard of anyone
got them once in Scotland REMRAND TIMBER AND BUILDERS SUPPLY keep my beads in a tube in van but could not slide them in or out stick together like carpet gripsNo never see them in merchants.
Wonder if plast1stop would divulge if they have had any repeat orders , don't know how to do blue name link lolgot them once in Scotland REMRAND TIMBER AND BUILDERS SUPPLY keep my beads in a tube in van but could not slide them in or out stick together like carpet grips
Do you bed the bead before nailing , perhaps I'm not understanding as if the bead isn't solid , Ott me , I tape as well lolUnifinish and clout nails rule
