john simpson
quick question for a job.
Using insulation boards in an upstairs bedroom with a laminate floor.
Going to scribe the ends of the laminate away to match the depth of the boards/skirting.
Do i need to leave a gap then between floor and board? or just cut them tight and let them rest on the sub floor?
Walls are sound but had wallpaper , would you PVA or Blue Grit? using dry-lining adhesive but a bit worried about excess wallpaper paste etc with the boards being heavy.
Also , should i put a line right along the skirting? with them being for insulation im thinking i dont want too much circulation but that might be bad for the wall or just standard dabs?
